Taranis X9d plus
Page 2 sur 2
Page 2 sur 2 • 1, 2
Re: Taranis X9d plus
Aucun doute, c'est bien une X9D+ 2019.
Je viens de flasher une de mes X9D+.
Le flash dure environ 15/20s et j'ai tout cela qui s'affiche:
Tu as bien la même chose ?
- Code:
C:/Program Files (x86)/OpenTX/Companion 2.3/dfu-util.exe -a 0 --dfuse-address 0x08000000:524288 --device 0483:df11 -UC:/Users/sebastien/AppData/Local/Temp/6024-flash-check.bin
dfu-util 0.7
Copyright 2005-2008 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2012 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to dfu-util@lists.gnumonks.org
Filter on vendor = 0x0483 product = 0xdf11
Opening DFU capable USB device... ID 0483:df11
Run-time device DFU version 011a
Found DFU: [0483:df11] devnum=0, cfg=1, intf=0, alt=0, name="@Internal Flash /0x08000000/04*016Kg,01*064Kg,07*128Kg"
Claiming USB DFU Interface...
Setting Alternate Setting #0 ...
Determining device status: state = dfuERROR, status = 10
dfuERROR, clearing status
Determining device status: state = dfuIDLE, status = 0
dfuIDLE, continuing
DFU mode device DFU version 011a
Device returned transfer size 2048
DfuSe interface name: "Internal Flash "
bytes_per_hash=2048
Starting upload: [###############################################################################################################################################################################################################################################################] finished!
C:/Program Files (x86)/OpenTX/Companion 2.3/dfu-util.exe -a 0 --dfuse-address 0x08000000 --device 0483:df11 -DC:/Users/sebastien/AppData/Local/Temp/6024-flash.bin
dfu-util 0.7
Determining device status: state = dfuUPLOAD-IDLE, status = 0
aborting previous incomplete transfer
dfuIDLE, continuing
Downloading to address = 0x08000000, size = 432064
File downloaded successfully
No valid DFU suffix signature
Warning: File has no DFU suffix
Oui j'ai la même chose, je vois pas du tout où est le pb
romnae- Messages : 30
Je vais la balancer contre un mur lol
1. Ta radio est neuve ?
2. Elle s'allumait bien lorsque tu l'as reçu ?
3. As-tu essayé avec un autre cordon USB ? (très important)
4. Si tu peux, essaye de refaire la manip Zadig sur un autre PC.
LapinFou a écrit:1. Ta radio est neuve ?
Bonjour, j'avais fait la manipulation chez un ami déjà, sur un autre pc avec un autre câble.
La radio fonctionnée avant mon erreur de fichier pour le flashage, j'ai cette radio depuis quelques mois et elle fonctionnait avant.
Là je sèche...
On ne peut pas bricker une Taranis en bon état. Avec Zadig, tu peux toujours récupérer une radio fonctionnelle.
A tout hasard, tu peux essayer d'injecter un firmware X9D+ (pas le X9D+ 2019) au cas où ta radio serait une contre-façon... Mais je doute sincèrement.
Pour moi, ta radio a un problème hardware.
Lorsque tu flashes une radio sous Companion (sans utiliser Zadig) avec un mauvais firmware, tu peux planter OpenTX mais PAS le bootloader.
Hors, dans ton cas, l'injection du mauvais firmware à également planté le bootloader. Et ça, ce n'est clairement pas normal...
Tu me conseil d'acheter une autre radio alors ?
J'ai acheté celle ci plus de 200 euros, ça me contrarié un peu. Je ne pense pas que c'est une contrefaçon donc j'essaierai pas de mettre le firmware d'une x9d. Si tu trouve une autre idée je suis preneur.
Merci du temps que tu as consacré à me répondre et à m'aider.
Si je trouve de mon côté je te préviendrai.
Tu peux voir pour la garantie (en Europe, c'est 2 ans).
Autre solution, tu peux tenter chez quelqu'un qui maîtrise les radios OpenTX.
Page 2 sur 2 • 1, 2
» Quelle est la différence entre le firmware "Taranis" et "Taranis plus" ?
» TARANIS ET TARANIS PLUS POUR VERSION 2.2.3
» upgrader une taranis en taranis +
» SWR sur Taranis X9D plus.
» une taranis en plus!!
Page 2 sur 2
