Ethos - Mise à jour 1.4.14 du 06.11.2023 - Viable
ronron
Jccdu37
Dans ce topic, je vous propose de suivre et commenter les mises à jours d'Ethos (avancée, bug, etc ...)
Je le tiendrai à jour à chaque release.
Pre-Release 1.4.14 Pre-release
[New radios]
X14S
X14
[All]
Bigger indentation in the whole UI to improve readability
Value widget now displays the Trims values correctly
Higher threshold for sticks movement detection
Possibility to invert the left & right sliders direction
EM when long pressing return while editing a curve fixed
Logic Switch fix for min & max when comparing a LiPo sensor (single cell / cells count) to a value
[Lua] Timer::reset() fixed
[Lua] Source():reset() fixed
[Lua] lcd:invalidate() fixed on widgtes with a title
[XE]
Second LCD flicker fix
[X20 Pro]
Fix the bootloader so that it is possible to repair the Local Storage from Ethos Suite
Channels range of the internal module only allowed to be 8, 16 or 24 channels
[Ethos Suite]
Clean the cache when the APP is closed
Backup path will be saved according to radio types
Fix the name of the backup file
Add support for new radios
Mise à jour 1.4.12 du 25/09/23
[All]
Bootloader will give to Ethos Suite the Internal Module version
GPS coord field focus issue fixed
Rx Battery Voltage will accept a bigger range
Freeze fixed in Model Category selection
Missing Lua scripts won't make the model invalid on load
Lines reordered in Model / RF
Haptic used on critical alarms
Refactoring done in analogs & switches conversion between all radios
[X20PRO]
Bootloader freeze fix
EXT1 and EXT2 fixed
[X20HD]
Bootloader will give to Ethos Suite the Video Module version
[Simulator]
Sensor conflicts removed as they have no meaning in simulation mode
Mise à jour 1.4.11 du 17.08.2023
[All]
Black screen if power button was released too early
Trim delay removed on radios which don't need it
False "VFR low warning" avoided in many cases
Ghost telemetry improved
More receivers support added
Failsafe settings sent earlier to the receiver
Decimal fix in sensor values
Special chars support improved
Temperature sensor conversion °C / °F fixed
Navigation within Sensor pages improved (focus position changed when returning to the list)
[X20-PRO]
Power values on all bands were not saved correctly
External antennas settings fixed
[X18]
Texts adjustments to the LCD size, some sentences were clipped
[X12S]
Joystick support added
SI and SJ now displayed in Hardware Test
[Ethos Suite]
(For Windows) Won't install the update in C:\Program Files\ automatically. It will work when you update from 1.4.11 to a new version
Server selection will also work for checking update
Add Check update button
Remove country version for internal module information
Fix the version number of internal module information
Fix the crash when entering the Model manager
Auto updater may fail when you update to Suite 1.4.11. So it is strongly recommended to download the installer package and install Suite manually this time.
Release 1.4.10 intalled on X20 Pro systems is 1.4.9 with small differences like the TTS demonstration Special function created in each new model. It is therefore important to check that your X20 PRO has 1.4.11 before the first flights!
Mise à jour 1.4.9 du 16.06.2023
[All Radios]
Sticky logic switches didn't reset at "Reset Flight"
Telemetry was not fully reset at "Reset Flight"
Play Track was not saved correctly when used as global function
Focus lost when leaving Curve editing with [Exit Long]
Conditional mixes weights were limited to +/-100%
Throttle => Ele, Throttle => Rud and Butterfly mixes fixed. Please check your setup if you use one of those mixes with a curve!
Audio problem fixed (it stopped playing after the SD heavily used)
Screenshot correctly closed on Radio shutdown
New Switch Condition "Whole telemetry" added
New curves were not directly available in all dropdown menus within the same page
[X18 and Twin X-Lite]
Bigger font used
Top bar look & feel improved
A bientôt
Jc
[New radios]
X14S
X14
[All]
[XE]
[X20 Pro]
[Ethos Suite]
[All]
[X20PRO]
EXT1 and EXT2 fixed
[X20HD]
[Simulator]
[All]
[X20-PRO]
[X18]
[X12S]
[Ethos Suite]
[All Radios]
Bigger font used
A bientôt
Jc
Jccdu37- Messages : 234
Re: Ethos - Mise à jour 1.4.14 du 06.11.2023 - Viable
ronron- Messages : 446
Hello
On en est où finalement de cette 1.4.9? est elle mature? qui l'a installée?
sam26- Messages : 308
1.4.9 (version définitive) installée depuis "Ethos Suite" sans problème.
Encore un peu tôt pour dire si les améliorations annoncées en valent la peine.
Elle a été replubliée en définitive ce matin. Il s'agit d'une version de déboggage avant la 1.5 qui va apporter de nombreuses nouveautés comme la télémétrie sur le module externe.
Perso, j'ai les bug concerné par les deux premiers correctifs et intéressé par un ajout : New Switch Condition "Whole telemetry" added
Comme beaucoup, j'attends les premiers retours avant de l'installer.
Jc
Jc
Si mes anciens altimètre pouvais être fonctionnelle avec le xjt lite.
Cela serait bien.
Cela serait bien.
Denis "Jesus"- Messages : 110
Apparement, la comptabilité avec la télémétrie serait pour le matériel Fr-SKY mais aussi des autres marques, tout du moins seraient prises en compte les données télémétriques qui transitent par le récepteur. S'agissant du matériel Spektrum, je ne sais pas si ce qui est émis par les TM1000 (hors SRXL2), sera pris en compte.
Jc
Jc
il va y avoir la 1.410... avant
Proposée sans diffusion officielle il y a une quinzaine de jour, voilà la 1.14.11 en stable.
Encore du débug pour cette version mineure.
Jc
Jc
je lorgne sur la 1.4.1 depuis ce matin pour une machine tout neuve.
bon, si je comprends bien, il est urgent de ne rien faire ?
PIRKIROULE- Messages : 234
A chaque nouvelle version, je lorgne sur les nouveaux sujets déclarant des problèmes !
La 1.4.12 qui en est à ses prémices ne corrige rien d'important.
A+ Jc
A+ Jc
le 1.4.11 aurait il eu qq effet néfaste sur des anciens D6 et D8R XP ?!.
Je pense pas mais pk depuis j'ai qq souci avec ses récepteur ?
https://frskytaranis.forumactif.org/t13851-xjt-lite
J'ai surtout des X6R et X8R à valider + 1 Rx avec vario et 2 stabilisateurs s6r et s8r ? c'est ça ? mais il n'y a pas le feu ma X9E marche encore c'est donc pour une transition douce
Encore une mise à jour qui n'apporte que du débug.
Attention aux MAC équipés de versions antérieures à OSX 12. Ca bug.
Jc
Jc
Moi j'attends la 1.5.0 qui parait il sera avec beaucoup de nouveautés
Bonne soirée
Bonne soirée
Orion- Messages : 188
Sont attendues :
- Télémétrie sur le Multi Module
- Valeurs Variables (Important, mais je sais pas trop ce que c'est)
- Amélioration du wizard de création des modèles pour qu'il soit plus fin et produise une config plus aboutie.
A ce jour, le développement est à 81% terminé, avant déboggage final.
Jc
Sont attendues :
Jc
Il y aura aussi la checklist ce qui est bien pratique
Tu parles avant vol ? Car au boot de la radio, ca existe déjà.
Edit :
Amélioration de la Check-list
`Vu : https://github.com/FrSkyRC/ETHOS-Feedback-Community/issues/1465
Effectivement, c'est pas mal !
Les variables globales : (explication de Lapin Fou)
https://youtu.be/47y4eey6Mvw?si=7s5I0wdmIaWZqc8J&t=492
Jc
Edit :
Jc
Avec la 1.5.0, ca donnera ca :
Jc
Jc
oui, c'est ce que je voulais
J'avais pas compris au début, mais effectivement, c'est un plus.
Jc
Jc
C'est tres pratique, par exemple, tu notes 3S 2200mAh
CG à 165 mm
Hélice 12x6
Et tu peux mettre des volets et indiquer le bouton correspondant etc.....
CG à 165 mm
Hélice 12x6
» Mise à jour 1.4.12 du 25.09.2023
» ETHOS SUITE (Mise a jour)
» Mise à jour X20 avec Ethos
» Mise à jour de la radio, d'un récepteur, ou d'un capteur télémétrique depuis une radio sous ETHOS (X20 et X18)
» mise à jour X4R SB
