0pen TX 2.2 RC 8 N360 et Taranis X9D
+15
AlainR
grat450
cri.cri
claudev
Samy.p
taz26
19 participants
Page 3 sur 9
Page 3 sur 9 • 1, 2, 3, 4, 5, 6, 7, 8, 9
Re: 0pen TX 2.2 RC 8 N360 et Taranis X9D
Merci pour l'info, très intéressante cette fonction setTelemetryValue
sinon vous avez introduit pas mal de nouveautés LUA en 2.2, voilà ce que j'ai tiré de ton lien :
- Code:
@function sportTelemetryPop()
Pops a received SPORT packet from the queue.
Please note that only packets using a data ID within 0x5000 to 0x50FF (frame ID == 0x10),
as well as packets with a frame ID equal 0x32 (regardless of the data ID) will be passed to the LUA telemetry receive queue.
@function sportTelemetryPush()
This functions allows for sending SPORT telemetry data toward the receiver,
and more generally, to anything connected SPORT bus on the receiver or transmitter.
When called without parameters, it will only return the status of the ouput buffer without sending anything.
@function crossfireTelemetryPop()
@function crossfireTelemetryPush()
This functions allows for sending telemetry data toward the TBS Crossfire link.
@function getRAS()
Return the RAS value or nil if no valid hardware found
@function luaPlayHaptic(duration, pause [, flags])
Generate haptic feedback
@function popupWarning(title, event)
Raises a pop-up on screen that shows a warning
@function popupConfirmation(title, event)
Raises a pop-up on screen that asks for confirmation
@function setTelemetryValue(id, subID, instance, value [, unit] [, precision [, name])
@param id Id of the sensor
@param subID subID of the sensor, usually 0
@param instance instance of the sensor (SensorID)
@param value fed to the sensor
@param unit unit of the sensor.
* `0 or not present` UNIT_RAW.
* `!= 0` Valid values are 1 (UNIT_VOLTS), 2 (UNIT_AMPS), 3 (UNIT_MILLIAMPS),
4 (UNIT_KTS), 5 (UNIT_METERS_PER_SECOND), 6 (UNIT_FEET_PER_SECOND), 7 (UNIT_KMH), 8 (UNIT_MPH), 9 (UNIT_METERS),
10 (UNIT_FEET), 11 (UNIT_CELSIUS), 12 (UNIT_FAHRENHEIT), 13 (UNIT_PERCENT), 14 (UNIT_MAH), 15 (UNIT_WATTS),
16 (UNIT_MILLIWATTS), 17 (UNIT_DB), 18 (UNIT_RPMS), 19 (UNIT_G), 20 (UNIT_DEGREE), 21 (UNIT_RADIANS),
22 (UNIT_MILLILITERS), 23 (UNIT_FLOZ), 24 (UNIT_HOURS), 25 (UNIT_MINUTES), 26 (UNIT_SECONDS), 27 (UNIT_CELLS),
28 (UNIT_DATETIME), 29 (UNIT_GPS), 30 (UNIT_BITFIELD), 31 (UNIT_TEXT)
@function getRSSI()
Get RSSI value as well as low and critical RSSI alarm levels (in dB)
dev.fred- Messages : 760
@3djc : une question me taraude , je n'ai pas encore testé ton programme mais pourquoi local myArrayPercentList est-il déclaré 2 fois ?
Cool, bien vu, c'est ce qui arrive quant on manie le copier coller avec la délicatesse d'une hache . Il y a avait d'autre déclaration a revoir !
- Code:
-- LUA Mix Script
local outputs = { "Cel%" }
---- Déclarations en variables globales pour une portée étendue au script de télémétrie
local myArrayPercentList =
-----## Table Robbe fiable modifiée pour départ à 3.0V --## Tableau de decharge LIPO
{{3, 0}, {3.093, 1}, {3.196, 2}, {3.301, 3}, {3.401, 4}, {3.477, 5}, {3.544, 6}, {3.601, 7}, {3.637, 8}, {3.664, 9}, {3.679, 10}, {3.683, 11}, {3.689, 12}, {3.692, 13}, {3.705, 14}, {3.71, 15}, {3.713, 16}, {3.715, 17}, {3.72, 18}, {3.731, 19}, {3.735, 20}, {3.744, 21}, {3.753, 22}, {3.756, 23}, {3.758, 24}, {3.762, 25}, {3.767, 26}, {3.774, 27}, {3.78, 28}, {3.783, 29}, {3.786, 30}, {3.789, 31}, {3.794, 32}, {3.797, 33}, {3.8, 34}, {3.802, 35}, {3.805, 36}, {3.808, 37}, {3.811, 38}, {3.815, 39}, {3.818, 40}, {3.822, 41}, {3.825, 42}, {3.829, 43}, {3.833, 44}, {3.836, 45}, {3.84, 46}, {3.843, 47}, {3.847, 48}, {3.85, 49}, {3.854, 50}, {3.857, 51}, {3.86, 52}, {3.863, 53}, {3.866, 54}, {3.87, 55}, {3.874, 56}, {3.879, 57}, {3.888, 58}, {3.893, 59}, {3.897, 60}, {3.902, 61}, {3.906, 62}, {3.911, 63}, {3.918, 64}, {3.923, 65}, {3.928, 66}, {3.939, 67}, {3.943, 68}, {3.949, 69}, {3.955, 70}, {3.961, 71}, {3.968, 72}, {3.974, 73}, {3.981, 74}, {3.987, 75}, {3.994, 76}, {4.001, 77}, {4.007, 78}, {4.014, 79}, {4.021, 80}, {4.029, 81}, {4.036, 82}, {4.044, 83}, {4.052, 84}, {4.062, 85}, {4.074, 86}, {4.085, 87}, {4.095, 88}, {4.105, 89}, {4.111, 90}, {4.116, 91}, {4.12, 92}, {4.125, 93}, {4.129, 94}, {4.135, 95}, {4.145, 96}, {4.176, 97}, {4.179, 98}, {4.193, 99}, {4.2, 100}}
---- Calcul du pourcentage : Pas de virgule
function percentcell(targetVoltage)
result = 0
for i, v in ipairs( myArrayPercentList ) do
if v[ 1 ] >= targetVoltage then
result = v[ 2 ]
break
end
end
return result
end
local function run()
cellResult, cellsum, cellsumtype = 0, 0, 0
cellResult = getValue("Cels") --## Appel du tableau retourné par le capteur FLVSS
if type(cellResult) == "table" then --## Vérif du format de valeur retournée (Table)
cellsum = 0 --## Raz cellsum (évite addition infinie)
cellsumtype = #cellResult --## Nombre d'éléments détectés
for i, v in pairs(cellResult) do --## Boucle for qui isole chaque valeurs de la table
cellsum = cellsum + v --## Addition de chaque éléments pour valeur totale du pack
end -- end for
cellsumpercent = percentcell(cellsum/cellsumtype) --## Pourcentage du pack
else
cellsumtype = math.ceil(cellResult / 4.25)
cellsumpercent = percentcell(cellResult/cellsumtype)
end -- end if
setTelemetryValue(0x0310, 0, 1, cellsumpercent, 13, 0, "CelP")
return cellsumpercent * 10,24
end
return { run=run, output=outputs }
Merci, je teste/utilise dés que je passe en 2.2-RC8.
Pas trop de risque l'hiver en Bretagne; je ne fais voler que des quads et des mousses EPP dans un gymnase à l’abri du vent.
J'ai rien compris , là , ca doit etre mon coté Brice de Nice qui ressort .......
Je vous un peu perdu depuis que vous etes parti à fond dans vos script LUA ....
Donc , concrètement et en francais , j'aimai bien mon petit scipt LUA qui me permettait de visualiser ma capacité et voltage de ma batterie Lipo , est ce qu'il y a un moyen de le faire fonctionner en Open TX 2.2 ou c'est mort ?
cri.cri- Messages : 657
Il faut juste que Heisenberg adapte son script pour 2.2, en l'occurrence lcd.lock() n'existe plus, donc il faut au minimum supprimer la ligne 97, ce qui le rend fonctionnel sans bénéficier des nouveauté de 2.2
Qu'est ce qui empêche de faire une implémentation inoffensive de lcd.lock() en 2.2 pour garder la compatibilité ?
3djc a écrit:.../...désormais il existe en 2.2 une nouvelle fonction LUA setTelemetryValue (https://github.com/opentx/opentx/blob/next/radio/src/lua/api_general.cpp#L1013) qui permet de créer des senseurs 'virtuels' issue d'un peu ce que l'on veut, et notament de calcul en lua.../...c 'est un senseur a tout les points de vue...
Je fais des bonds !!!
Clairement, c'est vraiment très puissant !
Vraiment sympa cette nouvelle fonction :
Encore un petit nettoyage: plus besoin de retourner la valeur cellsumpercent et de déclarer un output.
- Code:
-- LUA Mix Script OpenTx 2.2
result = 0
result = v[ 2 ]
break
end
end
return result
end
end -- end for
else
end -- end if
end
return { run=run }
C'est possible ne rien retourner, mais j'ai préférer le laisser car comme ca on voit ce qui passe dans l'écran custom fonctions.
Une sorte de mode Debug tant que la fonction setTelemetryValue n'est pas au point.
Sinon tu écrivais "Non, cette technique avait plusieurs défaut", quels étaient les défauts de l'ancienne méthode ou les avantages de la nouvelle ?
Bonjour, j'ai du louper quelque chose, j'avais la version 2.0.11 et j'ai flashé la 2.2.0 RC8 et cela ne fonctionne pas comme je l'aurais espéré : pas d'écran à l'allumage ni après d'ailleurs ....
Samy.p- Messages : 193
A mon avis tu aurais du passer par la 2.1.9 et refaire un formatage EEPROM puis ensuite passer à la 2.2.0. Mais de mon point de vue, la version 2.2.0 est obligatoire pour la Horus. Mais pour la X9D/X9E je préfère encore rester en 2.1.9. Trop de problème avec la dernière version du soft...
Sans compter qu'à force de formater l'USB avec ZADIG puis avec DFU-UTIL j'ai fichu en l'air mes port USB et je n'arrive plus à lire mes cartes SD et Companion 2.1 ne reconnait plus la Taranis.
J'ai trouvé, sur la carte SD j'avais FIRMWARE au lieu de FIRMWARES ....
S'il y a des soucis, le plus efficace serait sans doute de les remonter. Perso, je vole en 2.2 depuis 6 mois sur X9e ..
J'ai installé cette version 2.2 sur ma taranis plus.
Ca marche plutôt bien sauf que le fichier predimRC.lua ne fonctionne pas.
Je l'ai renommé predim.lua puisque il ne faut pas dépasser les 6 caractères mais c'est pareil.
Une idée?
Une idée?
diiity- Messages : 1950
Aucune idée de ce que c'est, a part regarder s'il y a un lcd.lock() qui n'existe plus en 2.2, il faut voir avec l'auteur du script
Oui effectivement, il y a lcd lock() et aussi lcd.clear().
Dans ce cas que faut il faire?
Adapter le script pour 2.2
Ah là c'est une autre affaire!!!
une petit conseil
je démarre de zéro (quelque soit la radio) et reçois une X9D d'ici quelques jours et j'ai "buché" pas mal de docs et tuto
lors de l'instal d'opentx je pars directement sur la branche 2.2 en utilisant le manuel Horus ou bien je reste sur la branche 2.1 ?
une petit conseil
cri.cri a écrit:J'ai lu et cru comprendre qu'on pouvait passer la Taranis sous Open TX 2.2 RC 8, si c'est le cas , quelle en sont les avantages et éventuel inconvénient par rapport à la branche 2.1.9 ?
pourquoi dans Compagon on ne voit pas cette mise à jour ?
Sans doute parce que tu n'a pas activé les nightlies
@Roller
Pour ma part, je resterais en 2.1.9.
La 2.2.0 n'est encore qu'une release candidate. Sauf à devoir impérativement utiliser une 2.2.0 pour de bonnes raisons, il vaut certainement mieux attendre une version de production.
De toute manière tu auras déjà largement de quoi t'occuper avec une 2.1.9
» 0pen TX 2.2 RC 9 N361 et Taranis plus
» companion 2.2 N360 pour la taranis plus
» OpenTX 2.2.0 RC8 (N360)
» Quelle est la différence entre le firmware "Taranis" et "Taranis plus" ?
» TARANIS ET TARANIS PLUS POUR VERSION 2.2.3
Page 3 sur 9
